Does Not Like to Start When the Engine is Warm
DGrant09
Post by DGrant09 »
We have a 390, fresh rebuild and new battery that is hard to start when it warms up. It will act like the battery is weak, but it is new and once the engine cools it will start fine. Once this week I jump started it when this was occurring. I have not seen any indications of a weak battery or a slow alternator (dimming lights etc..). Should I be looking at the start system or charging system. These are the only two items we have not replaced recently!
Dan
09", F350, Cabelas, 6.4L
72", F250, CS, 390, 2 WD
michael69
re: Does Not Like to Start When the Engine is Warm
Post by michael69 »
Sounds like you may have a starter problem. When starters start going bad they will drag and act like battery is weak when they get hot.
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
19674x4
Post by 19674x4 »
sounds like a bad starter to me. check all connections as well
My Photo Album
2012 Cummins-the luxury Tow Pig
1967 F-250 highboy 352, np435(((((((sold))))))))) My first true love
1968 F100 SWB. 360, np-435, flatbed, currently acting as a hornest nest and bee hive.
1971 F-100 4x4 Step-side. 360, np-435, 70k origional miles- needs allot of love.
Joshpow
Post by Joshpow »
Possible timing issue. If the timing is extremely out of whack, it may still run ok and start fine cold. After the engine gets warm it will sound like the starter is not powerful enough to spin the engine. My 72 had the same problem, and a re check on timing showed it was off. I reset the timing down to factory specs and the problem went away. Don't know if this is your problem, but it may be worth a try.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
http://www.cardomain.com/ride/2972100
DGrant09
Post by DGrant09 »
Thanks for the ideas! Looking at the starter and what was mentioned above I picked up a new starter and ran the truck to the shop. We looked at the amp draw to the starter when it was acting up and sure enough it was excessive. Now we have a new starter!! All I have left is the alternator and the engine will be new! Ouch!! It is running nicer - :-)
Thanks for your help!!
Dan
BiggDogg
Post by BiggDogg »
I've been having the same problem but haven't had a chance to investigate it yet. Pretty sure its the starter though cuz its pretty old. Any starter brand recommendations before I go shopping?
1970 F250 Camper Special
"Its no coincidence that man's best friend can't talk."
willowbilly3
Post by willowbilly3 »
After you attempt to start it, go feel of all the battery cable connections. If any are hot you have a bad connection. I agree it is probably a tired starter. I would go have a system test done by a shop with a Snap-on AVR, Vat-40 or similiar test equipment. They can test the whole sysrtem in about 5 minutes.
DGrant09
Post by DGrant09 »
Well, as for the connections and wires. The only wire that is old runs from the start relay to the starter. I've had wires look ok but were corroded inside the insulation to the point they no longer worked. As for the wire temp - Yep they get ^&@# hot when it is acting up!
We'll see today how the truck does with the new starter. I have to run up to Fairbanks and back.
DGrant09
Post by DGrant09 »
Quick update.. The truck has done great with over 700 miles since the new starter went in on Saturday!!
Thanks again,
Dan
